Bathroom Walls & Ceiling - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-15-2013, 04:41 PM   #1
Rewards Points: 31
I am currently remodeling a small bathroom down to the studs and installing an acrylic tub/surround from Sterling. I have an exhaust fan (there's no window) and this bathroom gets HEAVY use, so I'm trying to determine what the best wall and ceiling covering would be.
I've read about greenboard, fiberock, Zinsser mildew resistant paints, etc. To really moisture-proof this bathroom, should I install any kind of barrier behind any greenboard/backerboard? Or should a membrane go over the greenboard, like Kerdi etc.? (probably a stupid question, I know). I know there are acrylic panels as well, but not sure if they can go directly to studs and how effective they are. I've also read people on the forums not liking the expense of those as well.
Outdoorbum is offline   Reply With Quote
Old 04-15-2013, 05:03 PM   #2
Rewards Points: 13,748
Green board or Denshield is what I would use.
There's going to be some say just use reguler drywall to save a few bucks but why take the chance by cheaping out.
No barrier needed under or over it, just a Primer like Zineer 123 and paint rated for bathrooms.
DO NOT FALL FOR THE PRIMER IN ONE SCAM.
Old 04-15-2013, 05:15 PM   #3
Rewards Points: 31
So just attach the Greenboard or Denshield to the studs with no other waterproofing? Yeah, I figured on priming separately. Thanks!
Old 04-15-2013, 05:19 PM   #4
If there's no tile involved there's no need for anything else.
daxinarian (06-03-2016)
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 06:07 PM
starting with walls vs ceiling autx790 Drywall & Plaster 9 07-06-2011 04:00 PM
How to frame basement walls with 9' ceiling jigglyman Building & Construction 5 03-14-2011 09:20 PM
New walls, old ceiling with texture... do I tape? rodney23 Drywall & Plaster 12 02-15-2011 10:38 PM
Dark color & downlighting to reduce ugly ceiling in downtown loft bathroom? fredonian Painting 3 08-17-2009 09:20 AM
