Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 08-01-2011, 05:55 PM   #1
Bathroom venting near gable vent?
Howdy,
Our bathroom has a ventilation fan, but it vents into the attic, so I want to run a vent out through the side of the house. The gable end of the attic is less than 3 feet away.
If I head straight out, I will come out less than a foot below the gable vent.
My question is:
Should I be concerned about the wet air working its way back into the attic through the gable vent, or will this be OK?
The alternative would be to mount a vent fan in a bathroom wall, and run the ducting through an adjacent closet. This would make the outlet several feet away from the gable vent.
Hope all this makes sense.
Thanks,
John
jdhoskins is offline   Reply With Quote
Old 08-10-2011, 11:12 AM   #2
If the vent is already in the attic, can't you open a hole in the roof away from the gable vent?
Ron
B. Franklin 1759
Old 08-10-2011, 08:08 PM   #3
I could, but frankly I am too chicken to cut a hole in the roof ;-)
When I was a kid, I recall a roofing DIY project I helped my father do which went wrong, and I have shied away from roof work ever since.
Old 08-10-2011, 09:36 PM   #4
You will need to get on a ladder to mount the vent. How steep is the roof?
Ron
B. Franklin 1759
Old 08-10-2011, 10:52 PM   #5
No, it's not the height or pitch.
I'm not confident in the sealing and waterproofing, and would rather go through the wall with it.
Old 08-10-2011, 10:54 PM   #6
There might be less water on the houses side, but you still need to make it water tight.
Ron
B. Franklin 1759
Bathroom vent damper staying open BlueBSH HVAC 2 12-27-2010 07:11 AM
attach bathroom fan vent to dryer vent hohadcr HVAC 9 03-08-2010 06:58 PM
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-27-2008 11:25 PM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 01:36 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
