Bathroom Ventalation - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-13-2008, 10:59 PM   #1
bathroom ventalation
I am finishing a bathroom in my basement, but have no way to vent it outside. Are there any solutions to this problem?
miller01 is offline   Reply With Quote
Old 10-14-2008, 01:49 PM   #2
You can use an in-line vent if it meets code in your area, but you're still going to have to vent it to the attic I believe.
martyshel is offline   Reply With Quote
Old 10-14-2008, 03:27 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
NO vent is to be vented inside, including into an attic. That will only add all of the moisture there being exhausted from the bathroom for instance.
All vents should be vented through a wall or out the roof.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 10-15-2008, 01:02 PM   #4
I was talking about a plumbing vent, not an exhaust fan vent. The in-line vent I was referring to is actually called an AAV (air-admittance valve).
Old 10-16-2008, 01:37 AM   #5
Long-Time DIYer
Right.
www.studor.net
IF allowed by local code, as stated.
Old 10-16-2008, 05:04 PM   #6
It's already vented for the plumbing. I was wondering about the exhaust fan. Sorry, I should have specified. The exterior wall it is next to is stone and there is duct work surrounding the other three directions.
Old 11-16-2008, 07:53 PM   #7
You can drill through stone. As long as this isn't a castle with 9 foot walls.
Mike Finley is offline   Reply With Quote
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 12:04 PM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 11:10 AM
