Bathroom Vanity Install - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-03-2011, 02:02 PM   #1
LSK
Bathroom vanity install
We are going to install a new vanity and sink in our bathroom but we will be replacing the flooring in that bathroom as well. Which should be put down first?
LSK is offline   Reply With Quote
Old 09-03-2011, 02:16 PM   #2
m1951mm's Avatar
I would put the floor down first. Then you will not have a bunch of small cuts be it sheet goods or tile around the vanity. If it is not setting perfectly on the new floor, then you can add shoe moulding around the vanity without worrining if it will cover any gaps on the floor.
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
The Following User Says Thank You to m1951mm For This Useful Post:
LSK (09-03-2011)
Old 09-03-2011, 03:39 PM   #3
DIY staff
Rewards Points: 7,174
Yep! Floor first---it's faster to set the tile---if the vanity ever needs replacing the old 'foot print' won't matter.
LSK (09-03-2011)
New Bathroom Install, Plumber or DIY? detarevosipeels Plumbing 13 06-14-2011 11:52 AM
Need advice on what easy to install / inexpensive flooring options for bathroom floor amodoko Flooring 9 06-04-2011 04:23 PM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 04:56 PM
Bathroom vanity? StevePax General DIY Discussions 5 11-08-2009 04:48 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
