Bathroom Sub-floor Mess: See Pics - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-27-2012, 12:03 PM   #16
Rewards Points: 150
Originally Posted by LittleMissDIY View Post
well the floor feels solid other than in the spot where the OSB was rotted... the tile in that bathroom is through out the house (BLEH!) and the grout is coming out but from what i understand the tile is pretty old and hasnt been regrouted before
If I got what you said correctly, your floor joists are on a 12" OC build-out? Also, your joists are (at least) 2x8s? If so, you should have nothing to worry about.
oodssoo is offline   Reply With Quote
Old 12-27-2012, 12:06 PM   #17
Rewards Points: 236
well. you do have to post the joist size and length. you are going to be asked that, again. just go in the basement and measure. they are probably 1 3/4" x 7 1/4" x ??
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
oodssoo (12-27-2012)
Old 12-27-2012, 12:19 PM   #18
its about 1 5/8" by 9 1/2"
LittleMissDIY is offline   Reply With Quote
Old 12-27-2012, 12:21 PM   #19
Rewards Points: 150
So you have 2x10 joists.
How far apart spacing between the joists?
Old 12-27-2012, 12:26 PM   #20
they are a foot apart... i have no clue how long but i do have pictures.... the bathroom has a ton of posts.... i dont think deflection will be to bad since there are 4 posts for just this bathroom.... my stepdad thinks the previous owners screwed something up then hired someone to fix it
Pics:
Bathroom Sub-floor Mess: See Pics-img_0472.jpg   Bathroom Sub-floor Mess: See Pics-img_0473.jpg   Bathroom Sub-floor Mess: See Pics-img_0474.jpg   Bathroom Sub-floor Mess: See Pics-img_0475.jpg
Old 12-27-2012, 12:56 PM   #21
DIY staff
Rewards Points: 7,174
This is what's needed for us to determine your deflection';
Joist size--2x10?
Grade and type of wood--old house? Likely douglas fir?
Spacing---go measure that
And unsupported length---(distance from foundation to beam or post--)
Get that and one of us will check our charts and give you the deflection.
360 is minimum for tile 760 id minimum for natural stone
Old 12-27-2012, 02:30 PM   #22
ok well... there is 12 inches between and the foundation wall is on the other side of the stairs pictured next to the metal post above (just a little over 3 feet)... the other foundation walls are 10-20 ft with other posts in as well... my measuring tape isnt that long.... as for the grade and type of wood, i have no idea what it is or how to find out. our country doesnt keep records of houses built and said even if they had the fire they had in the 70s would have destroyed them
Old 12-27-2012, 04:56 PM   #23
DIY staff
How about a picture showing the ceiling of the whole basement?
Those joists are rough sawn and heavier than the joist of today---You may be okay---I fust wonder why so much extra support was added after the house was built.
Old 12-27-2012, 05:51 PM   #24
well the bathroom was not original and there was probably not enough support there for anything because they used to just cover the area under the stairs up. Also there have been walls taken out (such as the one that seperates the foyer/stairs from the living room) and added (such as the closet in the foyer they had built). Honestly the newer layout works better than ones i have seen that are similar. We also have an uneeded servents stair case in the kitchen which is original to the house but unusable... we will be hiring people to take it out in the future. The basement is a brick foundation and one side was anchored in 06 because it started to crumble in. I am guessing that the added support in this area is due to all of these things since they are all within the same area.
The Following User Says Thank You to LittleMissDIY For This Useful Post:
oh'mike (12-28-2012)
Old 02-02-2013, 02:10 AM   #25
Late to this thread but couldn't help noticing the galvanized metal straps holding up the copper water pipes (2nd pic above) - that's eventually going to cause galvanic reaction and corrosion. Change them for copper or plastic straps.
The 90 degree copper bend in the 4th pic completely covered in green needs to be repaired before it also corrodes further and bursts.
1st pic (more clearly seen in 3rd pic) shows the pvc pipe support missed the pipe completely - just hanging there.
profcolli is offline   Reply With Quote
Old 02-04-2013, 03:38 PM   #26
Good to know... for now all work has stopped due to money... not sure when we will be able to finish because we have to buy a new vehicle
oh'mike (02-04-2013)
Old 02-04-2013, 04:46 PM   #27
DIY staff
Little Miss you are not alone with your tight money----
We are a lot like a family here----Have some chicken soup---you'll feel better---
Keep us posted as you start up again----Mike-----
Old 06-20-2013, 12:45 PM   #28
Well... the money issues are not as bad and we have a birthday coming up in a couple weeks.... our goal is to completely have the bathroom finished by July 7th.... sooo we have this weekend and next weekend to get it done... cant this weekend so next weekend it is... will be calling the in laws for speed and probably stealing the toilet from the 2nd half bath upstairs.... granted i will be replacing the guts in it with the guts from the old toilet since they dont work properly... my to do list til then is to get the wall paper off.... thanks for all the support!!
Also I found out today that no one in our town will touch our basement.... i need a contractor willing to lift 2500 sqft and build me my basement without telling me im crazy and it costs more than my home is worth..... i dont care if its more than my home is probably worth in this town, its my home and i want it to feel like home... any comments or contacts for that would be much appreciated...
oh'mike (06-20-2013)
Basement Bathroom - plumbing thoughts (pics) rkerns Plumbing 1 01-12-2011 04:14 PM
Bathroom Venting on Septic System edro Plumbing 2 01-03-2011 07:41 AM
help with bathroom fan and light on separate switches, pics attached detyianni Electrical 10 10-29-2010 01:06 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 11:43 AM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 11:04 AM
