Bathroom Shower Window Replacement Question - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-09-2009, 11:02 PM   #1
Fire Tech
Question
I just purchased a home that needs a little TLC. I need to replace a window in a bathroom, which is located above a bathtub. I have all the material I need. I am asking around to see if anyone may have some tips on what to seal, cover or protect the window from the shower. I Have seen tile used in some other applications. If I do that would I need cement board to do this the right way. Or are there some other options. I am open to Ideas.
Jonnyonthespot is offline   Reply With Quote
Old 06-10-2009, 07:27 AM   #2
Window should be vinyl with opaque glass, nothing that needs covering. Any tile in a shower should be over cement board or hardibacker.
Old 06-10-2009, 08:01 AM   #3
Tired & Dirty
Rewards Points: 83
agreed on an all vinyl window, but I would put a short slider in so it is above the water splash line and neighbors can't see in, I know how it is to have a full length window in shower/tub, it Su**s! If your doing some remodeling now is a good time to do it, you will not regret it.
evapman is offline   Reply With Quote
Old 06-10-2009, 08:48 AM   #4
Rewards Points: 5,336
It would help if the post included more details of the job.
What type of a window? Is this part of a larger renovation on this wall or is it just a replacement window going into the old wood frame?
Where were you going to put the cement board?
Ron
Old 06-10-2009, 11:41 PM   #5
Fire Tech
The bathroom is the only room being renovated. the rough window size is 30"w X 38"t. I am thinking of installing a 24"X24" sliding window. I plan on covering the entire bathtub area with the cement board. The window trim will be tile. So I was wandering if I should use the cement board around the window or is there a different app. that I could use.
Old 06-11-2009, 08:14 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Generally, we advise people (who want to keep a window in a shower location), to: Order, and install a vinyl window. Order it without window jambs. When installing it in the old window opening, rather than using wood trim work, use PVC composite (non wood) trim. Use it for the window jambs, casings, and apron. When installing the stool (interior sill), pitch it slightly for water drainage. Use mold/mildew resistant caulking. Paint with an exterior grade, mold/mildew resistant paint.
If these things are beyond your skill level, consider highering a qualified and experienced carpenter.
- Build Well -
Old 06-15-2009, 12:54 PM   #7
Renovation Contractor
Paragon's Avatar
Rewards Points: 150
How about using glass block for the window?
http://paragonbathrooms.com/northmoorhead.aspx
Scroll down 3/4 down the page and you can see the edge of the glass block
Good Luck!
Paragon is offline   Reply With Quote
Basement window replacement topher0524 Building & Construction 7 05-21-2009 03:59 PM
bathroom shower in basement along foundation wall jeeper Building & Construction 1 04-16-2009 08:20 PM
Vinyl Window Replacement aschau01 General DIY Discussions 2 12-23-2008 06:17 PM
Replacement Window - Nail Fin Question smoenra General DIY Discussions 12 09-04-2008 11:19 AM
