Bathroom- Shower Door Magnet - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-22-2012, 02:32 PM   #1
Firstly, hi all I'm new here. Just bought a house recently and so I hope to learn a lot from you all and of course as I learn I hope to pass that on to others who have similar experiences as me.
So here is my dilemma. My framed shower door magnet need replaced. The door keeps swinging open and won't stay shut. I'm trying to remove the magnet but I can't figure out how to. There are 2 screws (top and bottom) of the side of the door but it doesn't look like that affects the magnet. I've also tried tugging at it from the top or bottom to try to pull it out and that hasn't worked either. Am I not tugging hard enough or am I missing something?
Thanks for the help! I can provide pictures if needed as well
Sketch is offline   Reply With Quote
Old 05-22-2012, 09:06 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Pics are always helpful.
Old 06-19-2012, 08:57 AM   #3
Removing and replacing magnetic strips on your shower door is quite easy so if your are having difficulties, then you must be doing it the wrong way.
To remove the magnetic strip, you need to remove the latch first because this holds the magnet into place. You mentioned something about screws? Those must be the ones you need to unscrew to remove the latch and expose the strip. When you are done unscrewing and removing the latch, it will be easier to peel the magnet off.
This is indeed a common problem when you have swinging framed shower doors...fortunately this can be managed by doing a simple repair.
ellechan is offline   Reply With Quote
The Following User Says Thank You to ellechan For This Useful Post:
PaliBob (07-02-2012)
Bathroom ceiling with vapour barrier - shower light / exhaust fan mforeman1 Drywall & Plaster 1 04-03-2011 07:19 PM
Bathroom \ Shower question. Abs777 Drywall & Plaster 14 03-09-2011 07:11 AM
Bathroom Window / shower mazzonetv Building & Construction 4 02-21-2011 04:25 PM
Bathroom remodel - lighting over shower / water line s4alex Electrical 15 10-10-2008 02:15 AM
Bathroom Shower jackco711 Flooring 4 11-14-2006 10:22 AM
