Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 09-28-2012, 11:18 PM   #1
Bathroom Renovation Gone Wrong? (You will not believe this picture)
Hello,
My wife and I have recently brought in a contractor to convert our half bath master into a full bathroom. This is our first time hiring outside workers for remodeling, and we are unweary about both the progress and quality of work thus far. The space available was 46" in length for a shower, however, the contractor has "tried" to install a 48" basin. To do so, he has cut into the walls studs (pictured) is this up to code? My wife is extremely irritated with the length of time this process is taking. The original contract quoted completion by 9/30. They are no where near complete as the basin is not even installed completely. My concern is not the length of time, but the quality of the work. I think cutting into the studs is a ridiculous solution to a problem that should have been seen beforehand. Is this ruining the structural integrity of our house?
So, we are at a point where we have paid 33% down. I am fine walking away from the contract, allowing the contractor to keep my deposit for the plumbing and work done to this point (if he fixes the studs), and finishing it myself. Is this logical? Or am I simply overreacting by expecting a contractor to perform at a much higher standard than myself?
Any help or advice (or even your opinion) would be greatly appreciated.
brm6685 is offline   Reply With Quote
Old 09-28-2012, 11:34 PM   #2
Was his name Fred Flintstone? What does he plan on doing for the shower walls with that hack job?
Can't tell by your picture but is the stud closes to the camera hacked even worse?
If these studs are on the outside wall, yes, they are load bearing. To correct it, you will simply have to sister any hacked studs with identically sized (length and width) studs.
Before giving up on that 33% deposit, I would ask a plumbing inspector to come in for pass/fail on the work he has done thus far and possibly consider lodging a complaint to state licensing board.
Good luck
allthumbsdiy is offline   Reply With Quote
The Following User Says Thank You to allthumbsdiy For This Useful Post:
brm6685 (09-29-2012)
Old 09-29-2012, 12:35 AM   #3
Yes, this is an exterior wall. So I am right to think that this would be a large structural integrity issue? I plan on having a lengthy discussion with the contractor about this tomorrow morning, and I want to have all of my points for the conversation. I just can not see what their plan is from here, and I am just so unbelievable angry that they would do this to the studs without even the slightest hint of talking about it before they went and hacked through.
Old 09-29-2012, 12:40 AM   #4
DIY Enthusiast
sublime2's Avatar
Cut your loses and RUN! What you see now is only the beginning of the corners he will be cutting ( no pun intended) to finish the job if you allowed him to.
I would have the next contractor inspect the work hes done before he finishes the work.
Any contractor you decide to go with,ask for references.call people that he has done work for.
If he's any good he will not have a problem with you contacting previous customers.
DO NOT continue with this hack! Pun intended!
sublime2 is offline   Reply With Quote
Old 09-29-2012, 06:27 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
What the Heck??!!
You did not hire a "contractor", you hired a wanna-be-contractor - TOTAL CLUELESS HACK.
Good thing you have stopped this butchery (of your house and your wallet) now, and not later.
That picture has got to go down as one of the "ALL TIME WORSE HACK JOBS" ever posted on this site = Seriously!!!
- Build Well -
The Following 3 Users Say Thank You to AtlanticWBConst. For This Useful Post:
BigJim (09-29-2012), gregzoll (09-30-2012), mae-ling (10-03-2012)
Old 09-29-2012, 06:33 AM   #6
Super Moderator
That is amazing----Is that a 'tile ready' pan--???? Everything in the picture is scary bad-----Bounce that guy----the money will be nothing compared to the future failures and repairs.
BigJim (09-29-2012)
Old 09-29-2012, 08:27 AM   #7
All of the above plus, where does he plan on putting the insulation on the outside wall?
Old 09-29-2012, 08:57 AM   #8
As others said, run away from this contractor. With a 46" space constraint, the contractor should have recommended a custom built shower pan and not tried to fit a standard 48" pan in the space. Just plain bad workmanship.
I 2nd the recommendation of bringing in a building inspector to look at this work. His professional opinion will give you another voice in the discussion you will be having with your contractor. Good luck - hang in there.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 09-29-2012, 03:32 PM   #9
Wow, your fears of bad workmanship are indeed founded. You cant take more than 1/4 of the stud width out of a load bearing wall, period. I would have him fix the studs and cut your losses. As suggested, get references next time you hire a contractor.
FTF-Tom is offline   Reply With Quote
Old 09-29-2012, 09:05 PM   #10
Ever tryed to fit a Qt. of Jello in a pint jar? Not going to work.
That's ugler then a fat person in spandex.
Old 09-30-2012, 04:54 AM   #11
paper hanger and painter
chrisn's Avatar
contractor?
I am just a dumb painter and know better than to cut out studs like that'you need to ask( next time) to actually see some credentials( license, insurance, etc)
chrisn is online now   Reply With Quote
Old 10-03-2012, 02:07 AM   #12
That is some amazingly creative idiocy. The contractor My Mom hired to do her bathroom 2 years ago which I just demolished because the city of Berkeley was about to recognize it as the "Cities only Rainforest" Would have handled that a little different.
For one, he would have stolen a serrated bread knife from our Kitchen and sawed 2 inches out of the middle of the shower pan and then use rubber cement and Scotch tape to rejoin the sides. Dear good if it's not level, those plastic placemats from Pottery Barn are apparently acceptable shim material. We always wondered what happen to one of our cutting boards. Well I found it below the tile he laid and he used that and a placemat to fill a hole in the subfloor.
How I feel your pain. Run and run fast!
RWPete is offline   Reply With Quote
Old 10-03-2012, 03:13 AM   #13
chrisn's Avatar
un freeking believable
Old 10-03-2012, 11:10 AM   #14
Please Please Please let him finish.
I want to see he does with that from this point.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
Edgar214 (12-04-2012)
Bathroom Renovation Ideas holyravioli Building & Construction 1 07-21-2012 07:02 PM
What's wrong with this picture? StrwbrySC Electrical 12 04-16-2012 03:14 AM
Bathroom Shower Floor installed wrong! newbathroomguy Building & Construction 10 11-07-2010 10:40 AM
Bathroom Renovation, separate outlet for whirlpool tub? ControlTech Electrical 9 06-23-2010 01:29 PM
Bathroom Renovation tips HHac8014 Building & Construction 2 04-19-2010 09:42 PM
