Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 06-03-2009, 01:03 PM   #1
Bathroom Reno
I just want to confirm if I have done everything correctly up to now in my bathroom reno. I removed all the old drywall around my old tub and replaced with 1/2" hardibacker, taped all joints and never had 4 corners meet. Plumber installed new tub then I tiled around according to tub specs and the grouted and sealed grout plus caulked all corners, around the tub and the ceiling. I have since ripped up 3/8" ply from floor replace with 1/4" hardibacker which was attached with thinset and screwed down, I then added a 3x5ft Nuheat flooring mat applied with same thinset. I am currently drywalling repairing after the initial demo and then I intend to prime the room, and then paint it. Tile the floor fully, I am hoping that its level enough after heating mat. Add toilet and vanity and fixtures.
PC Pro, DIY Noob
wedge22 is offline   Reply With Quote
Old 06-04-2009, 07:16 AM   #2
Bathroom Reno
Is there a question here somewhere?? Sonds like you have done a good job so far.
Old 06-04-2009, 01:59 PM   #3
Moderator
Bathroom Reno
I would have installed the tub, then the backer board over a vapor barrier on the bare studs. After furring the walls for the tub lip. On exterior walls, cut the wall v.b. to go into the tub.
Recommend 1-1/4" minimum ply for floor, before backer. Be safe, G
Surprise bathroom reno for my wife wedge22 Project Showcase 21 09-10-2009 02:59 PM
Making Walls Plumb in Bathroom Reno cbj8585 Building & Construction 4 05-20-2009 04:48 PM
Bathroom reno mrrenovater General Discussion 2 05-11-2009 07:01 AM
Basement Reno - Laundry, Bathroom mostr Building & Construction 2 03-02-2009 10:50 PM
replacing all above joists in bathroom reno... Bob the blunder Flooring 2 12-03-2008 09:40 AM
