Ok I am remodeling an upstairs bathroom and need some advice. I am using a cast iron shower base from Kohler and subway tiles in the shower and out around the walls 36" up. What is the best backer board materials to use in the shower, the ceiling and the rest of the walls?
Should I use a waterproof membrane over the backer board? Am I best to use a vapor barrier behind the backer board on the studs?
Has anyone here had any experience with the Dens sheild material?
I am doing this bathroom and want it done right. I expect it to last 50 years.
Not concerned about the cost, just the best method for avoiding moisture problems down the road.
Your not getting any play from the pros, so i will add to what has already been said. I am in the process of finishing my basement. I am going to use Redguard over Durock as a sealant. And no vapor barriers. That would create a sandwich for the moisture to be stuck inside of.
That's what I did except I used Hardibacker and then the redguard. Not sure about the Durock but I'm guessing it's the same thing as Hardibacker as far as absorbing moisture.
If you use Redgaurd make sure you prime the surface first with a Reguard/water mix (I believe it's 50/50 but double check) or the backer board will absorb all the water and the Redguard will not cure properly. Otherwise a very easy product to use and completely water-proof a shower.
I did my bathroom about 6 years ago. If I were going to do it again, I would use Kerdi board. I've never used it but it seems to be a lightweight product, easy to cut and work with, and waterproof when you seal the edges. http://www.schluterkerdiboard.com/
Thanks for the input all. I am still unsure which way I am going to go, but it does seem I have several choices, and no one has thrown up a red flag to any of them. So thanks again, and keep th einput coming if you having something to add please.
:no:
In my mind, i can wrap the vapor barrier from around the three walls behind the green board that will be used outside the tub. i've never used redguard before so i was making sure it would work in my application.
No vapor barrier. Paint on waterproof membrane over CBU or Waterproof membrane like Kerdi. These are the accepted methods of constructing a waterproof shower now. If its water proof it will also be air tight. It will also keep water vapor from getting in the walls there too.
Sounds like Redguard (or the like) is the way to go...thanks
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
