Bathroom Remodel - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-12-2009, 03:07 AM   #1
Send a message via Yahoo to Wolfeye
Bathroom remodel
I'm in the middle of remodeling my bathroom and I had a question about my window sill. We just put in a new window in the shower wall and I planned on installing the window sill with an oak board and tile on top, side and bottom. I also was going to seal it with oil based Drylock.
I am of modest budget so nothing extravagant is possible. I've searched local resale lots for stone but nothing I've found comes close to matching anything else in the bathroom.
My question is this: Would the sealed wood be a decent form for a tiled window sill in the shower? Other suggestions?
Wolfeye is offline   Reply With Quote
Old 01-12-2009, 07:16 AM   #2
Remodeling Contractor
NO. you will need to use 1/4" CBU and a waterproof membrane.
Old 01-12-2009, 02:09 PM   #3
K&B Remodeler/Tile Guy
angus242's Avatar
You cannot use the wood for a tiling base. For one, wood and water don't mix and when you tile you are NOT waterproof. Water will penetrate and get to the substructure. Second, you cannot use thinset over a sealant. Even if you did decide to try this (highly unadvised), the chance of the tile actually remaining adhered is very unlikely.
Further more, if you did find some stone that would work, you do need to address the window sill area with waterproofing. Like I stated, a simple tile installation does NOT keep moisture from it's substructure. You can get a bucket of RedGard from Home Depot. It gets painted on and will give you a waterproof substructure that can be tiled over.
Good luck
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-12-2009, 03:55 PM   #4
The next question that I have is that now I'm going to be using the 1/4" CBU, the next problem I have is that the window sill is only 3" deep. I'd like to make it deeper but if I make it 4 inches out, the CBU doesn't leave much surface space to tile the facing edge at all. I can't build it up with a second CBU sheet because the tile would actually be higher than the top of the window frame. Is there a trick to fasten a strip of CBU below the sill but on the shower wall so I actually have some surface for tile?
Old 01-13-2009, 11:32 AM   #5
angus242's Avatar
I'm not totally understanding this situation. I think I do but if there's a way you can post a picture, I'd have more to go off of for a suggestion.
Angus
My Albums
Old 11-03-2010, 03:06 PM   #6
Ultimatetouch
Use durock and then paint the sealer on. Dont know the name but it is usually red or green sealer. Then go over with tile.
_____________
Ultimatetouch
Bathroom Remodeling Company, Kitchen Remodeling Company
ultimatetouch is offline   Reply With Quote
Old 11-03-2010, 03:53 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
ultimatetouch, but not ultimately perceptive.
You have responded to an entry that is approaching two years old.
XXX
Bathroom Remodel MeraleeCrowl Remodeling 4 01-11-2009 07:28 PM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 11:04 AM
Bathroom remodel - need advice sparky472 Remodeling 12 10-22-2007 04:03 PM
HELP! How should I remodel my bathroom for the highest return profit?? nidaxny General DIY Discussions 2 03-20-2007 12:32 AM
Approach to demo bathroom ceramic tile floor for remodel corky Flooring 3 01-29-2007 09:59 AM
