Bathroom Remodel - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-09-2013, 09:27 PM   #16
Rewards Points: 31
So I have decided to move where the supply line comes down, over to the right of the joist pictured for accessibility in the wall above. I would like it to connect to the current spot under the floor however to maintain the course of the line under the floor. Should I notch the joist to accomplish this or go underneath it?
I also attached another picture where the line lays on top of a main support beam then bends slightly to clear the joists underneath. I figured notching here would put less stress on the joints and make a cleaner run . Am I thinking right?
Outdoorbum is offline   Reply With Quote
Old 07-09-2013, 09:31 PM   #17
Rewards Points: 31
Here is the picture, the line is the one running left to right. You can see how it ducks under the joists.
I suppose I could notch the main support beams (2 of them) and hang everything below the joists. Using a hole hog or something to deal with the thickness
Old 07-10-2013, 12:55 AM   #18
Rewards Points: 31
http://www.nachi.org/forum/attachmen...ing-small-.jpg
Here is something I found that explains my issue. My support beam is a 3 1/2 x 5 1/2 that has posts every 78 inches. The notch cut in the beam to accommodate the old tub drain is set in from one end 23 inches. Its 4 inches wide and 2 1/2 deep on one side . In my mind, way to big given the above diagram. The attached picture shows the line I would like to run through a notch , obviously running right next to the old drain.
My first thought is to put a support post of the same size as the beam right under the notch . I dont know how to get a post under there where its tight without some suggestions. Then, do I dare notch that beam another 3/4 inches given its state now ?
Bathroom Remodel-2013-07-09_20-26-50_603.jpg   Bathroom Remodel-2013-07-09_20-31-55_314.jpg
Old 07-10-2013, 03:22 AM   #19
DIY staff
Rewards Points: 7,174
Do not notch a joist or beam ---drill a hole---notches should be avoided as they weaken the structure.
Old 07-15-2013, 06:08 PM   #20
DIY staff
How's it going? No new notches from your work,right?
Old 07-16-2013, 09:10 AM   #21
Pro
Rewards Points: 91
Don't notch your beams for water supply; supply lines don't need straight runs the way drains do.
CarpenterSFO is offline   Reply With Quote
Old 07-16-2013, 01:47 PM   #22
Rewards Points: 31
Nope! Running supply lines without any additional notches. Unfortunately, the original plumber notched a couple of beams with what appears to be a 1" auger so I'll use those since they are already present.
Old 07-17-2013, 01:22 PM   #23
Rewards Points: 31
Toilet Drain
Old 07-17-2013, 09:43 PM   #24
DIY staff
You PMed me about moving the drain flange over 8"---You can cut the lateral line and use a 45 to move the toilet drain over 8"--always avoid using a 90 on a toilet drain---they can be used with success sometimes--but rodding the line would be difficult and a 90 might lead to a slow drain---
TheEplumber (07-17-2013)
Old 07-22-2013, 03:21 PM   #25
Rewards Points: 31
Mike (or anyone for that matter), referring to the additional support on post #18 in this thread, would you set the post directly under the notch or mid span to support everything?
Old 07-22-2013, 07:41 PM   #26
DIY staff
Place the support right under the notch----sister in another joist if there is room----Mike-----
Old 07-22-2013, 09:23 PM   #27
Rewards Points: 31
sister by screwing in a 2 x 6 maybe? How long, just between the two original posts ? Its 6 1/2 feet between
Old 07-22-2013, 10:33 PM   #28
DIY staff
If you can add a 2x? along side the notched floor joist--glued and nailed--for the full length--there will be no need for a post---even part way will help---Mike----
Old 07-23-2013, 01:42 AM   #29
Rewards Points: 31
Ok great! 16 d nails every 8 inches or so? Should I go galvanized?
Old 07-23-2013, 06:25 AM   #30
DIY staff
12 or 16 P nails--about 10" is fine
Newbie with bathroom remodel pierrekitty Remodeling 20 03-10-2011 05:22 AM
Ideas For Basement Bathroom Remodel DrHicks Kitchen & Bath Remodeling 8 01-21-2011 04:53 PM
General Steps to a bathroom remodel jdt141 Building & Construction 1 01-10-2011 08:32 PM
Noob bathroom remodel jep Kitchen & Bath Remodeling 18 11-22-2009 11:56 AM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 12:04 PM
