Bathroom Re-tile: How Far To Go W/demo - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-02-2012, 08:32 PM   #1
Bathroom Re-tile: how far to go w/demo
I've started a remodel a bathroom in a house built in 1988. The floor was pretty easy. Now for the bath surround.
There were no visible issues, cracked tiles, etc. just needed updating. After removing a couple of tiles I thought I was dealing with tiles on top of old cement board on top of drywall. Tile had a big bullnose where they met the drywall next to the bath area. All the tile came off easy enough. When I started on the cement board I discovered that it appears to be on top of mortar.
The question is how far should I demo? Since I want to tile all the way to the ceiling want the surround underlayment to be flush with adjoining drywall, I assumed I needed to demo down to the studs. After encountering the mortar I am not sure I am doing the right thing. Looking for confirmation before I demo any further.
cmills is offline   Reply With Quote
Old 02-02-2012, 08:36 PM   #2
Rewards Points: 582
pictures would help but I think you should go to the studs to acheive the best possible results...ben
Old 02-02-2012, 10:29 PM   #3
the wall in question
This shows the cement board and underlying mortar. I assume there is wire mesh embedded. If the best path is to go down to studs any tips on easiest demo?
Old 02-02-2012, 11:10 PM   #4
MarginallyQualified
Rewards Points: 2,464
It's time for the big guns and no half stepping allowed.
Take it down to the studs and start over.
IOW... buy a bigger hammer.
(and rent a rotary)
The Following User Says Thank You to TarheelTerp For This Useful Post:
ben's plumbing (02-03-2012)
Old 02-03-2012, 12:05 AM   #5
Rewards Points: 582
yep take er down...get a couple hungry boys tell the you will feed them for some help no really get some big boys..ben
Old 02-03-2012, 09:58 AM   #6
Awesome. Nothing like wrecking something. Will a Saws-all work or will I need something more heavy duty?
Old 02-04-2012, 07:25 PM   #7
MarginallyQualified
It'll sure come in handy at times but the main tool is a rotary hammer:
Old 02-04-2012, 07:29 PM   #8
Rewards Points: 582
no matter what tool you use eye protection..and keep in mind there is other things in wall..wires, pipes plumbing and heating..etc,,have fun but be careful...ben
Subfloor and Porcelain tile prep sugarhousemama Flooring 4 12-03-2010 07:47 PM
Failing bathroom tile floor--best options quinten Flooring 3 11-16-2010 07:56 PM
Bathroom Renovation-To Tile or not to tile jte1130 Remodeling 7 04-14-2009 11:39 AM
Help! Botched bathroom tile job steamed17 Remodeling 13 05-01-2008 10:40 PM
Approach to demo bathroom ceramic tile floor for remodel corky Flooring 3 01-29-2007 10:59 AM
