Bathroom Medicine Cabinet And Light Rough In - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 10:53 AM   #1
Rewards Points: 1,600
Bathroom medicine cabinet and light rough in
I am framing in a wall for the remodeled bath and would like to frame in the box for the medicine cabinet as well as the junction boxes for the sconces on both sides of the cabinet.
Only I have not yet decided what medicine cabinet to get and what scones to get yet.
For the medicine cabinet I am thinking a 24"W x 36"H one, although this may change, I might end up with a 18" wide one. So what is the best way to do the rough framing for this if the precise size is not yet known? It will be recessed into the wall that's why I want to frame in a 2x4 box. I assume even a standard 24x36 cabinet different manufacturers have different rough in dimensions?
Also how tall should the box be mounted? May be it is sufficient to just frame the upper lower horizontal members and not worry about the vertical pieces?
Related to that is there a standard height to mount the sconces on both sides of the cabinet? I don't know what sconces I will be using, I assume if the scones point up you mount the electrical boxes lower and if you use downward pointing scones you mount it higher? Or no such rule?
How far horizontally from the edge of the cabinet to the scones? 6 inches? 12 inches?
Thanks in advance.
miamicuse is offline   Reply With Quote
Old 05-02-2012, 08:30 PM   #2
I would look through some pics online or in magazines before you pick your items. That way you can figure out what you like and copy it as best you can in your bathroom.
As for installing all the items you'll know better about where to place your lights, etc.
Fantastic is offline   Reply With Quote
Trying to install lighted medicine cabinet shortfry16 Electrical 6 03-25-2012 09:32 PM
How to Customize Thin Wall Cabinet with Light cjakins Electrical 0 11-15-2011 09:24 PM
Replacing Bathroom Light with Fan quinten Electrical 5 10-29-2010 09:25 PM
Halogen light in Cabinet? hyunelan2 General DIY Discussions 2 08-18-2010 12:05 AM
Bathroom Light Cover Over Cabinet Broken petrusprimus Kitchen & Bath Remodeling 2 06-09-2010 09:41 PM
