Bathroom Fan/ Light - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-20-2011, 12:39 PM   #1
Bathroom fan/ light
Hello, I am adding a fan/ light to my bathroom, the exhaust out of the fan is 4", my question is, does the exhaust have to be 4" pvc all the way out of the house or can it be reduced? If so, to what 3" or 2"? Thank you
homey42 is offline   Reply With Quote
Old 09-21-2011, 10:15 AM   #2
Rewards Points: 5,336
It should stay 4". Why are you using PVC as opposed to an aluminum rigid duct?
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
homey42 (09-21-2011)
Old 09-21-2011, 04:33 PM   #3
Thank you, the reason I said pvc is because, I have extra and the fan base is plastic. I didn't research any other avenue. But I will look into the aluminum rigid duct. Thanks again.
Old 09-22-2011, 09:43 PM   #4
Military Mom of 4
Snav's Avatar
Flexi-duct or alum-rigid are usually accepted per inspection.
PVC was not accepted per inspection for me - so I had to redo it. Might not be an issue where you're at but it was for me.
The reason why not to reduce is because these are designed to pump out through a 4" outlet - any build in air pressure (which can also result if you use a flex-hose that falls in and kinks up on itself) can bog down the fan's propulsion and even create water condensation (because it's venting steam) as well as overheat the motor. . .etc
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
The Following User Says Thank You to Snav For This Useful Post:
homey42 (09-24-2011)
Old 09-22-2011, 10:04 PM   #5
If you're running the ductwork through the attic or other cold areas, insulate the run.
Ron
B. Franklin 1759
Wiring for replacing a bathroom fan, heater, light and night light unit. tgallopbs Electrical 24 11-02-2010 09:57 AM
Replacing Bathroom Light with Fan quinten Electrical 5 10-29-2010 08:25 PM
Bathroom light with outlet in it? Jaded Electrical 12 04-15-2008 12:08 AM
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 09:46 AM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 06:25 PM
