Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 05-23-2009, 08:37 AM   #1
bathroom caulking
i just remolded my whole bathroom 3 months ago, and i notice in the tub area, the caulking by where the tile meets the tub is starting to crack in some areas, not much. my questions are should I just recaulk over it? scrap it off and caulk again? should i fill my tub up and let it sit then caulk it? its a fiberglass kohler deep tub. if i do scrap it, what should i use? thanks, the caulking i used was the one from the tile store that matched my grout.
fabian is offline   Reply With Quote
Old 05-23-2009, 09:27 AM   #2
bathroom caulking
I take it you didn't fill the tub the first time you caulked. That could be the issue. When you say cracking, do you mean separating from either the tub or the tile or is the caulk actually cracking within itself? If there was dust on either the tile bottom or the tub, you won't get good adhesion. Another possibility is that the caulk doesn't has the flexibility for the job. I always use a 100% silicone caulk in that area and at the wall junctions. Sometimes it doesn't match exactly, but it doesn't separate either.
I'd remove it all and start again. You can use a razor from a utility knife to carefully slice off the old caulk enough to get it ready for the new caulk.
Ron
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 01:17 AM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
Bathroom Caulking satchmo Flooring 7 06-13-2007 06:43 PM
