Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 02-01-2013, 07:32 AM   #1
Bathroom Backsplash Question
Ok, so I'm in the middle of a bathroom remodel (still in the plumbing stage), and we decided to change our plans slightly and add a tile backsplash/accent strip that goes around the room. Since it's going to be small tile (only a strip 5 3/4" high) and not in a constant state of high moisture exposure, I'm going to apply thinset directly to the new drywall. I thought about using a mastic, but I'm not really sure if that's really the best bet.
Anyways, I have a question about finishing the top edge of the tile where it meets the drywall. Do I use silicon caulking that matches the grout, or can it be left exposed?
mgh-pa is offline   Reply With Quote
Old 02-01-2013, 07:40 AM   #2
Super Moderator
No silicone there---paint will roll off of it---If that treatment must be used---use a color match grout from the file /grout manufacturer.
Fine installations would use a metal tile edging --Schluter has a good selection--many colors and styles.
Old 02-01-2013, 10:01 AM   #3
Is there any harm in leaving it untreated and exposed in this situation since there wouldn't be direct water contact, or would it just be safer to put it in? This will be put in place after painting.
Old 02-01-2013, 11:32 AM   #4
Super Moderator
It's just a look---I do not like the look of a raw tile edge capped with grout---
I see it a lot, so it is acceptable to some folks---so it you like the look--go right ahead---
Old 02-01-2013, 01:54 PM   #5
Well it is glass tile, not ceramic, so the edge is essentially the same. That's why I asked about leaving it unfinished due to not wanting to make more work than necessary
The Following User Says Thank You to mgh-pa For This Useful Post:
oh'mike (02-01-2013)
exhaust fan for bathroom question MLMIB Kitchen & Bath Remodeling 1 05-18-2012 03:34 PM
Bathroom Drywall Question bmwdr Drywall & Plaster 3 05-10-2012 10:29 AM
3 Part Backsplash question - Moved to Tile Section Smoke Tiling, ceramics, marble 10 04-10-2012 04:44 PM
Yet another bathroom exhaust fan venting question JulesB HVAC 23 03-10-2011 04:16 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 03:30 PM
