Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 03-19-2012, 02:45 PM   #1
Bath vanity installation
Hope this is a good place to post this question...
I am installing a bath vanity and the new one is about three inches shorter than the old one. Should i raise it up? Is there a standard height for something mike this?
toobhed is offline   Reply With Quote
Old 03-19-2012, 09:21 PM   #2
I think the standard height for base cabinets in general is 36"/ I don't know why yours would be shorter than that. Or was the old one taller? I think it really comes down to your personal preference. Sometimes tall people will bump up the heights of their cabinets especially in the kitchen to bring work surfaces to a more confortable level.
Jim F is offline   Reply With Quote
Old 04-02-2012, 02:25 PM   #3
Kitchen cabinets are nominally 34" high and 24" deep. 34' will yield a finished height of 36", assuming a 2" countertop.
On the other hand you will see a lot of variance from for vanity/bathroom cabinets. Traditionally, vanities were shorter (31" - 32") and not as deep (21"). Modern vanities size varies from one product line to the next.
Should you raise the cabinet? It will depend on the answer to a few questions:
1) What type of sink are you using? The cabinet is usually higher with an undermount and lower with vessel sink.
2) Will children use the bathroom and ages? With childrem you may need a lower sink
3) Height of the people using the sink?
4) What feels confortable to you? My wife and I like to to fill both hands with water then splash on our faces. So we discovered we like our sink higher than normal.
In my typical micro analysis method, my wife and I like a 35 inch cabinet with counter top when used with 4 to 5 inch deep vessel sink. We took the old vanity and raised and lowered it until we found the comfort range.
If you raise the cabinet split the shimming between the top and bottom. 1/4 round molding can cover the bottom and depending on the counter top you can place 1/2 to 3/4 plywood under it and won't show. If you raise just the bottom more than 1/2, the cabinets will look out of proportion.
goosebarry is offline   Reply With Quote
Relacing a shower with a half bath seth Building & Construction 9 11-22-2011 11:58 AM
Replacing bath room sink/faucet with vanity. pinecone12 Plumbing 6 10-15-2011 06:49 AM
Durock installation in bath, what side goes out? smcmurrey Building & Construction 8 12-12-2010 07:48 PM
Vanity - too tight a fit? Pat the Dad Building & Construction 7 12-14-2009 09:42 AM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
