Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 10-07-2010, 11:20 PM   #1
Bath in the shower stall
Thanks for your consideration! I have a large, tiled shower with an open face (no door, just curtain on one of the sides). Any ideas for how I could install an impermanent upright tub? Cheap way to build a water-tight container? that is not too large. Please and thank you....
novemberrain is offline   Reply With Quote
Old 10-08-2010, 10:56 AM   #2
Stuck in the 70's
Blondesense's Avatar
There is no way to turn a shower into a tub.
A large rubbermaid container is the first thing that comes to mind.
If you give us some idea of what this will be used for, it may help others with suggestions.
Advice about framing for a shower stall Tooncie Building & Construction 1 08-27-2010 09:54 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Help with shower pan removal - 1960s bath jm71 Kitchen & Bath Remodeling 6 11-23-2009 08:54 PM
shower stall with hole (cold air coming in) mcvane Plumbing 1 02-08-2009 11:41 PM
installing lights in shower stall mcvane Electrical 2 03-30-2007 06:34 AM
