Bath Floor - Concrete Board? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-17-2012, 06:18 PM   #1
Bath floor - concrete board?
Remodeling my bath. I have 3/4" sub floor under 9/16" osb. I was going to put tar paper down over that then 1/2" concrete board then tile. I'm wondering, do I need the concrete board? I can pull up the osb, tar paper under that and then tile over the osb. I imagine putting concrete board down is best but is it necessary? Thanks
schatzi is offline   Reply With Quote
Old 05-17-2012, 06:51 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
This thread may answer your questions.
OSB + Plywood = solid base for tiling?
Old 05-17-2012, 07:19 PM   #3
DIY staff
Rewards Points: 7,174
No need for half inch cement board--1/4" is fine---no tar paper--set the cement board into a bed of thinset--then nail or screw the board down---1/4 x1/4 inch trowel--
Old 05-18-2012, 12:19 AM   #4
Yep, very helpful. Thanks
New control board or fix it? Bobeht HVAC 26 01-18-2012 03:03 PM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 01:16 PM
Leveling Flake Board Sub Floor billfox Flooring 6 11-22-2011 10:08 PM
wooden board under sliding door Wiscbldr Building & Construction 1 07-08-2011 07:19 AM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 07:48 PM
