Bath Fan Roof Hood Creating Ice Dam - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-08-2014, 09:02 PM   #1
bath fan roof hood creating ice dam
I remodeled my bath a couple years ago and thought I was being wise by installing a vent fan. I went through the roof with it using a common hood that directs the moist air right on the roof creating a big ice dam! It's very cold here in northern Minnesota!! Is there something different I can use on the roof that is higher to help this problem?
jonolsen is offline   Reply With Quote
Old 01-08-2014, 09:09 PM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,864
It will always do that, due to the warm moist air, is reacting to the cold pile of snow around the vent. You need a Roof Rake, to get the snow off of your roof, to stop it. Also making sure that your bath fan has a self closing damper on it, to not let house air out through the vent, when it is not running.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
The Following User Says Thank You to gregzoll For This Useful Post:
jonolsen (01-08-2014)
Old 01-08-2014, 09:51 PM   #3
Thanks for the info. There's been times when there was no snow on the roof and this still happens!! Isn't there a different type of hood,pipe, something that will let this exhaust up higher and not right on to the roof?
Insulating kneewalls vs roof in 1929 house BadHouse Insulation 6 01-27-2013 03:58 PM
Repair + roof coating options Fishbone90 Roofing/Siding 23 11-12-2012 10:44 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
