Bath Fan Duct Questions - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-27-2013, 09:12 AM   #1
Bath fan duct questions
Bathroom fan duct questions:
Setup (pls see attached diagram): Fan w/ 4" duct --> semi-rigid duct pipe (I bought 4" diameter but can buy 3" based on answers) --> rigid duct pipe (slightly less than 3" diameter)
1. Bathroom fan has a 4" duct. I eventually need to reduce it to 3" (existing rigid duct has a diameter slightly less than 3"). Does it make a difference in terms of the static air pressure if I reduce it at the fan or if I put it at the end of a 55" 4-inch-diameter semi-rigid duct pipe?
2. When attaching the duct pipes, I would think that I'd want the pipe that is carrying the air flow to go INSIDE the pipe it's attaching to (as opposed to fitting OUTSIDE the pipe it's going to attach to) in order to avoid leakage of the air (even with foil tape and a clamp). Is this correct or ... does it not matter?
** NOTE: if I were to attach, for example, the 4 to 3" reducer to the INSIDE of the Rigid Duct (see diagram), I'd, of course, get some flexible duct or another solution to ensure that it fit inside the Rigid Duct.
Thx -
metazone is offline   Reply With Quote
Old 12-27-2013, 04:01 PM   #2
Rewards Points: 14,026
The right way would be to run 4" all the way.
Why does it need to be reduced?
Going loose a lot CFM, the fans going to have to work harder, may increase the sound level.
metazone (12-27-2013)
Old 12-27-2013, 04:32 PM   #3
Rewards Points: 3,130
There should be no reason you'd need to reduce the duct diameter anywhere. If you think there is, then it should be routed some other way. Most exhaust up and through the roof, though I don't particularly care for that - mine go straight through an outside wall.
The Following User Says Thank You to md2lgyk For This Useful Post:
Old 12-27-2013, 04:53 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
You will be fine adding the reduction at the end of the pipe.
The CFM Lose will be small if any.
As for attaching the pipes, use the shinny silver tape to cover all connections.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
Old 12-27-2013, 06:10 PM   #5
Rewards Points: 6,652
For the bath, you would be better to use insulated duct, to not allow any condensation from when the pipe cools, if there is still any humidity in it. You can get the flex duct with the R-5 insulation on it at your local Big Box.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 12-27-2013, 07:53 PM   #6
Thanks, everyone, for the replies.
Goal: replace bath fan w/o changing rigid ducts -- calculated needed CFM for bathroom + EDL & bought fan based on this. Given this, reduction would be needed (not optimal but ...).
My remaining question: To reduce chance of air flow leakage (assuming using metal clamp and shiny silver foil tape): does it matter if the pipe with the air flow source is attached to the rigid duct on the OUTSIDE or the INSIDE? Thinking that pipe w/ the air flow source should go on the INSIDE?
Thanks -
Bill
Old 12-27-2013, 08:18 PM   #7
Registered User
Rewards Points: 526
Think of the exhaust air as water from your pump (fan), all should "drip" into the next one, toward the exit hood. Any irregularities inside will give turbulence, like the crimped (smaller) pipe (IF it were pointed at the air flow). With the reducer at the fan, the airflow in the whole duct will be faster, moving the moisture faster, giving less time to condense in the pipe. With the reducer near the exit hood, it will collect more condensation because it is colder there -- being closer to outside air (hood).
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Exhaust hood for range - Duct questions BigJimmy Kitchen & Bath Remodeling 0 09-22-2013 09:38 PM
Designing new ductwork. would love some input. Queequeg152 HVAC 8 08-30-2013 06:02 PM
New return duct size questions blackhemi HVAC 1 06-26-2011 06:50 AM
My Duct Sealing Project Cakemeister HVAC 6 06-13-2011 11:45 AM
bath exhaust fan questions rtoni HVAC 3 10-25-2007 03:46 AM
