Basement Shower Small Issue - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 06:31 AM   #1
Rewards Points: 211
Basement Shower small issue
Hello Folks,
I have a house (condo unit) with a finished basement that I bough about a year ago. In such basement there is a small shower, and apparently they use some sort of tape between the shower chamber and and shower enclosure, like shown in the following photo:
Seems to be a common tape that one would use to tape boxes, etc; and it is falling apart. Could any recommend another tape or something else.
tk3000 is offline   Reply With Quote
Old 03-26-2011, 09:07 AM   #2
Rewards Points: 5,336
Did it seem odd to you that someone put masking tape all over the walls? This isn't something you usually see in a bath renovation.
I would guess there was excess moisture in the room which caused the wall paper to peel. You can buy a wallpaper seam sealer and glue down the edges or you can remove the wallpaper and paint the wall.
New tape would not be on my list of options.
Ron
Old 04-13-2011, 12:06 PM   #3
Rewards Points: 211
Sorry about the delay in my response. Yeah, it seemed odd; I was wondering about it. But after having removed part of the tape it seems there is a gap between the wall cover (or panel) and the shower itself, as show in the following pic:
Would wall paper seem sealer be able to fill such gaps? Maybe the original job was not well done, there are lots of flaws that I found so far around the basement, such as the following:
It seems that the wall panels on which the wallpaper is glued to weren't properly aligned and trimmed in the above pic.
Also the wall panels on which the paperwalls are glued seemed to be popping out at some spots, so I am using the stud finder to find studs nearby and try to nail them down.
Thanks!
Old 04-13-2011, 12:41 PM   #4
You won't fix these issues with a seam sealer. The wallpaper is adhered to the paneling and installed poorly. It the shower area, I'd just pull it off the wall, patch and paint. The other areas you might just apply a corner molding to cover the gap until you decide to fully renovate the area.
It's got to look better then the masking tape.
Ron
Old 04-18-2011, 04:24 PM   #5
DIY'er
DIYadam's Avatar
Masking tape. A thousand and one uses except sealing a shower stall.
Honestly if it was me I would gut it and redo it all. Seeing masking tape would make me cringe. But thats just me.
DIYadam is offline   Reply With Quote
Old 04-18-2011, 10:08 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Those panels look like printed hardboard (Masonite) panels to me. You should be able to remove the stupid tape without damaging the panels (try a heat gun) then just caulk all of the cracks.
Are you sure that is wallpaper?
...and I thought I had seen everything!!!
XXX
Old 06-20-2011, 03:38 PM   #7
Rewards Points: 211
Thanks for the response guys, sorry I did not catch the response before. It seems to be hardboar with some decorative plastic wallpaper on it. The is room in the basement that uses that very same time of hardboard and some of them are slightly warped and popping up (and my stud finder have difficulties finding studing behind that material: hardboard with styrofoam and fiberglass behind it). The shower locate in the laundry part of the basement has other problems too, on its sides there are some panels that were not properly attached. All in all that finished basement has lots of issues...
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Basement Shower Remodel Question mdsnj Kitchen & Bath Remodeling 3 02-27-2010 01:16 PM
Basement Shower smells wdodds Plumbing 7 11-15-2009 09:31 PM
Big Mistake with a basement shower drain lindq175 Plumbing 4 10-06-2009 03:11 PM
