Base Cabinets Install W/ Leg Levelers??? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 08:37 AM   #1
Base cabinets install w/ leg levelers???
Hi everyone,
I am installing kitchen cabinets in my house. The floor isn't level. I've read online that leg levelers are the easiest way and you don't have to worry about the shims contracting and expanding with the seasons.
These are the leg levelers I purchased: Leg Levelers... Scherr's Cabinet and Doors Online Harware Ordering These seem to just go on the bottom of the cabinets. (These cabinets do not have the build in box/kick panel at the bottom of them like my cabinets)
However, my cabinets have have the wooden frame on the bottom (where the kick panel attaches to). They look like this[IMG]http://www.********************/images/smilies/frown.gif[/IMG]Sorry for the bad diagram, I can attach on if it will help)
l
I <---cabinet
I_____
L___ <--Kick panel/boxed in frame around the bottom of the cabinet
Does anyone know how to install these? I believe that they have to support the sides of the cabinets, since that will be what supports the granite countertop.
The only way they seem to be able to work now, is if I just put them under the cabinet, under the bottom shelf--but then it won't support the load bearing sides.
Can I just cut out some notches on all four corners? Any advice and insight is greatly appreciated. Thanks!!
remodelinghouse is offline   Reply With Quote
Old 02-02-2011, 08:42 AM   #2
Rewards Points: 5,336
I bought similiar ones from Rockler. They just screw to the bottom of the cabinet.
Ron
Old 02-02-2011, 08:45 AM   #3
Ron
So they don't have to go under the side panels? I thought that was what would support the granite??
Old 02-02-2011, 10:28 AM   #4
Yes, I would screw them in under the vertical supports. I have 3 cm granite on them for 7 years. The Rockler ones were rated for 400 lbs.
Ron
Old 02-02-2011, 11:07 AM   #5
Ron
That is where my issue is. The sides go all the way down and attach to the toekick (which is built into the cabinets). I just have a thin piece (which is painted to match the cabinets) that goes over this built int toe kick. These pieces extend about 6 inches below the bottom shelf.
These are the cabinets I havehttp://cabinetliquidators.com/c-11-h...glaze-hbg.aspx
Hopefully that makes sense?? Thanks for your help so far!
Old 02-02-2011, 11:59 AM   #6
Not so new
12penny's Avatar
Rewards Points: 520
....how far off level is the floor?
If infact the levelers get fastened to the underside of the cabinet bottom, and you are installing granite, I think shims are the easiest. Cant recall ever hearing anyone complain that their shims were cracking and popping when the seasons change. Add a few dabs of PL to the shims and they'll stay put.
12penny is offline   Reply With Quote
Old 02-02-2011, 12:04 PM   #7
Thanks, I might just return the leg levelers and eat the shipping cost if anyone doesn't have any other insight into how i can use them. I just thought they would be easier to install bc the corner cabinet looks like it is going to be a pain to get level with the shims.
Old 02-02-2011, 12:06 PM   #8
Not so new
12penny's Avatar
Rewards Points: 520
You havent answered the question. How far out is it?
Old 02-02-2011, 02:20 PM   #9
Sorry about that... It isn't to far at all. I can put on shim under the rear right it and it levels the lazy suzan. It just isn't stable as the back side needs shims too. I tried a few times, but everytime I pulled the cabinet out and put a shim in the back, it screwed up the shims on the sides (the process just kept repeating itself).
Granted, I might have been a little picky as I prefer things to be exact.
The set up is only 3 cabinets long (lazy susan, 18 inch, 36 inch sink base and then dishwasher with an end panel. Should I lay the cabinets down and screw them all together, then put them in and try to level them as a unit or level each on separate from the other.
Old 02-02-2011, 02:36 PM   #10
With the cabinets you refer to, you use shims to level the cabinets, not the leg levelers.
Ron
Old 02-03-2011, 08:52 AM   #11
Not so new
12penny's Avatar
Rewards Points: 520
....stick the shim to the floor with a little construction adhesive, or tape, or caulk, or whatever you have around.
Base cabinet install on uneven floor no1hustler General DIY Discussions 4 10-13-2010 02:52 PM
Can You Install Any Cabinets in a Garage limitdiy Carpentry 7 05-08-2010 01:32 PM
Slate under cabinets? CCP Remodeling 2 03-09-2010 03:57 PM
Bullnose Base Moulding Install Rick5472 Carpentry 16 09-21-2009 09:44 AM
Base cabinets on floor TonyD Carpentry 15 10-23-2006 10:53 PM
