Base Cabinet Mounting - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-06-2013, 08:05 PM   #1
Rewards Points: 240
base cabinet mounting
i am installing my base cabinets. i got to thinking if i am doing it right.
i level and square the box with shims in the front = where the sides of the box come to the floor. and a shim, if needed at the top back, if needed. then i am using cabinet screws into studs, through the shims.
what i am wondering : is this enough support ? we are getting granite. and that stuff is heavy.
am i doing enough ? can i do more ? if nothing but to make me feel better .
Fix'n it is offline   Reply With Quote
Old 11-07-2013, 02:47 AM   #2
DIY staff
Rewards Points: 7,174
Shim the bottoms at the front and back---then screw the boxes to the studs----at the top--clamp and screw the face frames together.
Old 11-07-2013, 11:49 AM   #3
K&B Designer
Live_Oak's Avatar
When you've found the high spot in the room, you use a level to draw a line 34.5" from that high spot, and that's the level from side to side. There's still front and back level as well. Make sure you are using plastic shims, not wood ones. Wood compresses and will give you issues down the road. When you've established how many shims will give you that, and you screw them to the wall, then you insert as many more as you can to give support. Be sure you are shimming correctly, using 2 shims, so one side of the cabinet isn't lesser supported. They should go in from either side like this >< to achieve the correct height.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 11-07-2013, 08:18 PM   #4
Rewards Points: 240
how do you shim the backs, when there is no reasonable access ?
Old 11-07-2013, 08:26 PM   #5
Rewards Points: 240
how can i put shims in from the side, when that side is up against another cabinet ?
plastic shims, i will look for them.
the way i have the shims now, i could stand on the cabinets and they are solid.
but all the weight, at the front of the cabinets, is sitting on a pretty small contact area.
Painting grooves in kitchen cabinet doors. jcraw84263 Painting 5 11-10-2011 12:05 PM
Sink base vs regular base cabinets... J187 Kitchen & Bath Remodeling 3 12-03-2010 07:40 AM
Need help! Cabinet install gone slightly wrong eemichael83 Carpentry 14 10-26-2010 03:46 PM
Looking for a Merilat base cabinet LHalvy Kitchen & Bath Remodeling 1 02-06-2010 04:03 PM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 03:29 PM
