Base Cabinet Flatness - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-20-2013, 11:00 AM   #1
Rewards Points: 216
Base cabinet flatness
i didn't want to jack bluebsh's thread. but i am having an issue somewhat like his.
i am setting the faces as close as can be, they line up well enough.
but, the cabinet box is way high in the back, about 1/8". how does a guy level the run of cabinets if the boxs are not flat ? i guess i could plane them flat(er)
Fix'n it is offline   Reply With Quote
Old 10-20-2013, 11:24 AM   #2
Rewards Points: 13,260
A level line should have been established on the back wall, then you measure down to find the high spot in the floor.
A new line is set level using that high point as a reference mark.
Cabinets get screwed to the back wall first then shimmed in the front to set them level.
A self leveling lazar level works great for this job.
Old 10-20-2013, 11:35 AM   #3
Rewards Points: 216
if i screwed them to the wall individually, idk if i even could get the faces to line up. though i did not try that.
Old 10-20-2013, 01:27 PM   #4
Easy to line them up if you use a set of clamps like this.
http://www.bing.com/images/search?q=...lectedIndex=19
Lines them up in two directions and acts as a drill guide.
A whole lot easier to also install then as a unit, not one at a time.
Old 10-21-2013, 09:43 AM   #5
Rewards Points: 216
yeah, i bet it is. but i am not going to buy thosse for one job.
Base color coat sticking better then primer? konsole Painting 8 08-22-2012 07:12 AM
Sink base vs regular base cabinets... J187 Kitchen & Bath Remodeling 3 12-03-2010 08:40 AM
Need help! Cabinet install gone slightly wrong eemichael83 Carpentry 14 10-26-2010 04:46 PM
Looking for a Merilat base cabinet LHalvy Kitchen & Bath Remodeling 1 02-06-2010 05:03 PM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 04:29 PM
