Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 02-03-2010, 03:30 PM   #1
Backsplash tile to granite counter top area
Getting ready to install a tile back splash in kitchen. Already have granite counter top. Where the first row of tiles meet the counter top, should you grout or caulk that area?
Thanks.
jay1028 is offline   Reply With Quote
Old 02-03-2010, 04:18 PM   #2
Thanks.
Silicone caulk.
Ron
Old 02-03-2010, 04:38 PM   #3
jlhaslip's Avatar
I use Dow Corning 786 Translucent there after using a strip of formica/arborite as a spacer for the tile.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 02-21-2010, 08:49 AM   #4
Finished the job. I was advised to use toothpicks as spacers for the tile to counter top area. Worked fine as I just wanted a small gap. Used GE Silicone II clear and cut a small 1/16" opening in the tip. It was relatively easy to control the flow with that small an opening. I read that alcohol was good to put on your finger to smooth the bead. It worked much better than any caulking job I had ever done.
Thanks for your help.
Want to change ceramic tile to granite tile smart2surf Flooring 3 06-24-2009 09:11 PM
Replacing tile surround with faux granite knharper Kitchen & Bath Remodeling 2 05-24-2009 12:25 PM
Install granite countertops first or stone backsplash?? ncoppola09 Remodeling 32 02-20-2007 02:00 PM
Electrical outlets and Granite backsplash, how? section8 Electrical 10 07-01-2006 09:53 AM
Granite Tile ....on wall ? mahjohn Building & Construction 7 03-01-2006 08:55 PM
