Backsplash Backerboard - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-29-2009, 06:49 PM   #1
dIYHell
Rewards Points: 150
backsplash backerboard
I am installing a cement backboard for a tile backsplash in my kitchen. There are several holes I need to cut for electrical outlets. Whats the best way to cut these. Should I measure and cut all the holes out of one continous piece or because this is just backerboard that will be tiled over I can cut smaller pieces to fit around this?
rocketdoctor is offline   Reply With Quote
Old 05-29-2009, 09:34 PM   #2
Remodeling Contractor
First you did not need backerboard. But cut the holes from a larger sheet, not pieces. Since these seams need to be flush. And remember that the boxes will now need box extensions, since the backerboard plus thinset plus tile exceeds code limit for a recessed box.
Old 05-30-2009, 12:26 PM   #3
dIYHell
Rewards Points: 150
Backing?
This is not clear to me, Right now there is drywall where backsplash goes are you saying I can tile directly to the drywall?
Old 05-30-2009, 01:13 PM   #4
Rewards Points: 5,336
Yes.
Ron
Old 05-30-2009, 10:50 PM   #5
Yes, you can glue the tile to the drywall. I don't think I've ever seen a backboard put up before.
I take that back, I did see someone add 3/8" plywood over the drywall once but cannot recall what their reasoning was behind attaching that particular backer.
jordy3738 is offline   Reply With Quote
Old 05-30-2009, 11:34 PM   #6
dIYHell
Rewards Points: 150
Thanks, the drywAll was painted will this be a problem?
Old 05-31-2009, 07:39 AM   #7
no, but if the paint is very glossy, just rough it up a little
Backerboard and Tile Project Question Livestrg05 Flooring 6 04-25-2009 08:35 AM
Attaching a backsplash to wall/countertop DanBress Carpentry 3 09-10-2008 09:09 PM
Tiling kitchen backsplash deeaa Building & Construction 6 07-17-2008 09:44 PM
Curved backerboard? mdalli Remodeling 7 04-22-2008 03:24 PM
Backsplash advice bigboyjoel Carpentry 11 05-29-2007 09:54 AM
