You can choose many different sizes and styles of glass block for decorating. The block comes in 4- to 8-inch squares and in a variety of smooth, textured, clear, and diffused styles. Before choosing your glass, decide how and where it will be used, so... Read More »
In the days of rising oil prices, seeking alternative energy as a way to heat your home during the winter is becoming increasingly important. Wood heating is gaining in popularity as wood stoves are readily available, but often they are in need of... Read More »
I'm Candi Cane Canncel with Expert Village. So we have installed our zipper in our new fun flared skirt and we have sewed it together and now the next step is to finish it. So we're going to start by ironing all the panels really flat and opening up all... Read More »
So what true stained glass is, a true stained glass piece, a stained glass window, a stained glass panel, even a stained glass lampshade, you can make stained glass boxes and other types of candle holders and things but true stained glass is really made... Read More »
Doors can be tricky simply because they have to look really good. Whether inside or outside, doors are one of the most visible areas of the house. They're usually well lit so every little drip and brush mark will show up. Use really good brushes for door... Read More »
