Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 01-08-2013, 03:02 PM   #1
diy'er
Attaching tread to stone tiles
Hey There,
Trying to attach a tread which comes in from the dining room with hardwood floors to the kitchen, which has stone tiles. I tried an all purpose adhesive from Lowes. Didn't work. I could nail the tread into the hardwood flooring ok, I'm just worried if it's not secure on the stone tiles it may come loose and tear up the hard wood flooring nailed on that side.
Any suggestions???
Thanks...
jvegas is offline   Reply With Quote
Old 01-08-2013, 04:34 PM   #2
Ya, post a picture so we can see what your talking about.
oh'mike (01-08-2013)
Old 01-08-2013, 05:15 PM   #3
Roofmaster
Neutral cure Silicone. They have one that sets in 4 hours. Make sure you place the beads about 2 inches in from the end so you can cut it with a sharp knife if you need to take it up. 2 inch double stick tape should work too, I would think.
" A lot of men build things, and a lot of things fall down "
Repairing 1950's loose shower tiles troyce1 Tiling, ceramics, marble 3 09-09-2012 06:43 AM
Stone Veneer Dry Stack over Brick Rotate Remodeling 7 01-05-2012 11:27 PM
Field Stone and Mortar Wall, will it be stable? NorskeDiv Landscaping & Lawn Care 4 07-14-2011 11:18 AM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 07:29 AM
calking backer board to tub glassman General Discussion 13 06-19-2008 09:41 PM
