Attaching A Support To A Shower Glass Partition - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-26-2012, 09:31 PM   #1
Rewards Points: 49
Attaching a support to a shower glass partition
I got this glass shower partition support rod that grabs the top of the glass
and spans across the width of the shower stall and anchors to the tiled wall. (keeps the glass wall from vibrating when i open the hinged door for the shower)
This support rod has a small end fitting with a hole in it for a screw.
The question is how to attach to the granite tile. Should i drill and use a toggle anchor? or is there a better screw/anchor to use?
Should i just use some epoxy to attach to the granite tile. (pad is 2" in diameter so should hold OK). Or construction adhesive.
any input is appreciated
john_bry is offline   Reply With Quote
Glass Shower mastersak Remodeling 9 06-12-2012 01:07 AM
Glass Shower Door ? behrend Plumbing 1 06-28-2010 02:37 PM
Adequate floor support for new shower? daveofnj Kitchen & Bath Remodeling 5 05-09-2010 02:27 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 08:19 PM
glass shower door removal ross General DIY Discussions 1 04-25-2005 06:22 AM
