Old 12-24-2011, 08:52 AM   #1
Share |
Applying venetian plaster over texture
What is the best method for applying venetian plaster on a textured wall?
landrews is offline   Reply With Quote
Old 01-22-2012, 12:21 AM   #2
WHAT is VENETIAN PLASTER?
bareshiyth is offline   Reply With Quote
Old 06-07-2012, 04:25 PM   #3
PLASTERS/VENETIAN WORK
Send a message via Skype™ to c_lindop
YOU WILL NEED TO RECOAT THE WALL WITH MUD OR PLASTER AND MAKE IT SMOOTH FIRST. I did a room that had orange peel texture on it and it shows in the final product finish.
c_lindop is offline   Reply With Quote
Old 06-07-2012, 04:26 PM   #4
I will need to be smooth and sealer aplied for the first coat of venetain plaster
Old 06-07-2012, 04:29 PM   #5
true venetian plaster is made of lime plaster mixed with crushed marble. The italians would take the left over marble and crush it up and use it in plaster. Basically i can make a whole wall look like a sheet of polished marble in just about any color you can think of.
Old 06-07-2012, 04:35 PM   #6
Also true Venetian plaster is not the same as the stuff you get at home depot. The stuff i buy is around $380 bucks per five gallon bucket and is a true product shipped in from Italy. The home depot stuff has a plastic look to it and no where even compares to the real stuff. Also all my tools are from italy and are special triangle shaped trowels with rounded corners for application. If you use a drywall knife it will show straight lines in the final product. I do 4 applications usually and then use a limestone paste to seal/wax it.
Faking Venetian Plaster / Knockdown (Sort of) PTP WX Drywall & Plaster 6 01-26-2011 04:59 PM
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
Can you texture plaster walls? destes50 Painting 5 11-06-2009 09:51 AM
Applying texture on smooth cement interior walls Flt_Simulation Remodeling 8 05-14-2009 05:23 PM
Texture to plaster bofusmosby Remodeling 2 05-05-2008 07:33 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
