Applying Glass Wall Tiles Directly On An Unfinished 2x4 - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-07-2011, 03:31 PM   #1
applying glass wall tiles directly on an unfinished 2x4
I'm tiling a shower with glass tiles. I'm using a Schleuter kit and due to a mismeasure I'd like to tile the end wall directly on the 2x4 because if I put concrete board on it the tiles will overlap the angle cut I made in the Schleuter curb. I would cover 2x4 with the Kerdi membrane first then tile it. My question is will the friggin tiles stick? As always thanks for your help.
beech is offline   Reply With Quote
Old 09-07-2011, 04:36 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
To the KERDI? Yes if the proper thinset is used.
The question is...will the KERDI stick to the wood?
Don't know for how long but again if the proper thinset is used probably yes. I wouldn't count on it tho. It's never a good idea to try and apply any tile product to dimensional lumber. You would NOT find that advice anywhere on any of the product labels. When you try to re-invent the wheel you are on your own.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
beech (09-07-2011)
Old 09-07-2011, 04:43 PM   #3
Thanks Bud. Do you think cutting shallow grooves in the 2x4 would help at all?
Old 09-07-2011, 04:55 PM   #4
kwikfishron's Avatar
Rewards Points: 194
Why don’t you just rip a ” off the 2x4s? Can’t be more than just a few.
kwikfishron is online now   Reply With Quote
Old 09-07-2011, 05:11 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Actually that may not be a bad idea.
I haven't a clue.
What thinset are you using?
XXX
Old 09-07-2011, 05:17 PM   #6
Rewards Points: 5,336
I don't think tiling a floating 2x4 would work. Too much movement.
Ron
B. Franklin 1759
Old 09-07-2011, 05:48 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Hey Ron!
XXX
Old 09-07-2011, 07:40 PM   #8
Thanks for all the replies. I think I may just put up a sheet of 1/4 inch concrete board and live with a little overhang. Thanks again guys.
The Following User Says Thank You to beech For This Useful Post:
Bud Cline (09-07-2011)
swap out bath wall tiles: re-tile or remove backerboard NJoytheRide Building & Construction 8 04-16-2011 08:52 AM
self sticking tiles - wall application peter_d_holmes Tiling, ceramics, marble 12 03-13-2011 06:18 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
basement wall directly over dirt? fivein06 Building & Construction 2 05-31-2010 06:50 AM
