#1 |
After removing tile wall
After removing tile from bathroom walls, how do I either eliminate the glue from behind, or smooth it as much as possible? Or what are my options to cover it up?
#2 |
the easiest way is to remove and replace the drywall. if you plan to retile it make it go much smoother and you will end up with a better job in the end. if its around a tub or shower you need to install some type of concrete backer board and waterproof it before you tile.
| Display Modes | |
| Removing tile; electric tile stripper or rotary hammer? | mackaz | Flooring | 0 | 07-21-2011 07:22 PM |
| replacing wall tile on uneven surface | johnpaul8379 | Kitchen & Bath Remodeling | 2 | 02-22-2011 04:26 PM |
| Removing Tile Over Hardwood: Need Help With Kitchen/Bath | Creelove | Flooring | 3 | 02-01-2011 07:03 AM |
| Trouble removing shower wall tiles | astroboy | Kitchen & Bath Remodeling | 2 | 01-30-2009 10:50 PM |
