-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   After removing tile wall (http://www.diychatroom.com/f80/after-removing-tile-wall-159874/)
Shoover 10-12-2012 06:46 PM
After removing tile from bathroom walls, how do I either eliminate the glue from behind, or smooth it as much as possible? Or what are my options to cover it up?
DannyT 10-12-2012 07:13 PM
the easiest way is to remove and replace the drywall. if you plan to retile it make it go much smoother and you will end up with a better job in the end. if its around a tub or shower you need to install some type of concrete backer board and waterproof it before you tile.
cleveman 10-12-2012 11:08 PM
What he said. Take it down to the framing.
