Acrylic Shower Base - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-20-2015, 10:26 AM   #1
Rewards Points: 602
Acrylic shower base
I’ve read that acrylic shower bases should be “embedded” into a mortar bed
Should that mortar bed be applied on cement board, or plywood is OK?
And does this mortar bed need to be applied with a notched trowel (in that case which size), or just flat?
french_guy is offline   Reply With Quote
Old 03-20-2015, 01:36 PM   #2
Rewards Points: 414
Acrylic shower base
Directly on the plywood is fine as long as its solid,
To set it just put a bed down and push the base down into the mortor bed
scottktmrider is offline   Reply With Quote
Old 03-20-2015, 01:55 PM   #3
Rewards Points: 5,250
Acrylic shower base
Some are self supporting, some come with a foam base built in.
If it is set in mortar I always lay felt paper down first. Wood in direct contact with concrete will rot the wood.
The way the mortars laid down will be in the directions with the pan or on line.
Any I've done the mortar was set in piles and the bed pushed down in it.
The piles are so there's room for it to spread out when compressed.
Old 03-20-2015, 02:08 PM   #4
Rewards Points: 602
Acrylic shower base
So you mean a few piles regularly placed, like a screw pattern?
(Something like 1 pile every 6")?
Old 03-20-2015, 02:33 PM   #5
Acrylic shower base
How far apart and how high if it's even needed will be right in the directions.
Old Yesterday, 05:39 AM   #6
Rewards Points: 602
Acrylic shower base
If you use felt paper (#15 roofing felt?), does that mean the shower pan + mortar bed only "rest" on the floor, since there is no direct adhesion between mortar and subfloor?
Installing pre-formed shower base pan svaic00 Plumbing 4 05-22-2013 07:08 PM
Frameless Glass Shower Install lynxpilot Kitchen & Bath Remodeling 12 10-23-2012 11:14 PM
How do you make a shower base for a oversized shower nateyro Kitchen & Bath Remodeling 4 01-17-2012 09:39 PM
Installing acrylic shower base onto concrete floor Dawna106 Flooring 0 10-15-2010 05:42 PM
How to build base for a shower stall atm Plumbing 13 05-13-2009 10:18 AM
