Acrylic bathtub support
I have successfully used spray foam to do this very thing on three (3) tub/shower units, one in my own home. Access to the bottom of the tub is the key here. IF AT ALL possible somehow place a contractors grade, large garbage bad in between the flooring and the bottom of the tub, then fill the bag with the foam. I have found that this tends to keep the foam in the area you are needing it, rather than having it just seep where it want to go. As stated, and important, I do fill the tubs about half-way with water (full should be fine also) to prevent the foam from causing the bottom of the tub to rise--ANY. The added weight of the water will make the foam spread out rather than try to rise also. Another trick I have learned it to buy some tubing which just fits over the tube of the spray foam tube, tape it to a dowel rod, yardstick, something solid, so you can guide the foam where you want it to go. This works when accessing the tub from one side. You may be able to use the tubing from under the tub, the basement side, to help place the foam. Think it through before actually spraying. Good Luck, David
