5 Piece Tub Surround? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-18-2012, 10:14 PM   #1
Rewards Points: 101
5 piece tub surround?
Not sure what section to post this under so I picked this section
I'm remodeling my bathroom and replace the cast tub with a new one. I roughed the plumbing based on using a 5 part tub/shower enclosure. I didn't realize until I bought one how cheap and flimsy they are. So now I've done all the work to get to this point and am not sure what to do. I can still go ahead with the 5 pc thing and hope for the best, I can't really tile because I put the tube valve thing in based just on the 1/2" drywall not another 1/2". Any suggestions or experience with the enclosures? Thanks, 1
1dumbquestion is offline   Reply With Quote
Old 03-19-2012, 05:39 AM   #2
DIY staff
Rewards Points: 7,174
There are 'extender kits' available for most brands of mixer valves---which would allow you to tile without moving the mixer to the proper position.
However---moving the mixer forward could be done simply enough in your situation.
As to the 5 piece surrounds---I've installed a few and I don't like them----cheap looking and they look old very fast if the tub is used frequently.
Old 03-19-2012, 06:56 PM   #3
Rewards Points: 101
thanks, I didn't know about the extender kits. sounds like I don't want to use the 5 pcs kit. so if I want to tile then I'm going to have a 1/2" thick exposure to take care of if I need to put cement board and tile over the drywall. any ideas on how to take care of that issue? Thanks, 1
Old 03-19-2012, 07:13 PM   #4
DIY staff
If you can post a picture of what you have--that would be a real help---
Also --what brand of mixer valve?
Most valves have a certain tolerance for missed measurements---You will have 1/2" Durrock and another 3/8" or so for tile----Install the plastic protector that comes with the valve and let us know how far out from the face of the studs---
Old 03-20-2012, 11:35 AM   #5
Rewards Points: 101
I've never had any luck posting pictures. the mixer is a Glacier Bay from HD. the plastic black spacer is flush with the front of the drywall. before I hung the drywall I test fitted the handle based on the this tub surrond and it seamed fine. but now that I'm considering tile I'm not sure? I assume putting tile right over the green drywall is not acceptable. I guess I could cut out the drywall and hang cement board on the studs and then tile, but I was hoping to not rip out what I just finished. advise? thanks, 1
Old 03-20-2012, 11:55 AM   #6
Rewards Points: 13,988
Glacier Bay is the cheapest of the cheap brand of faucets, in most cases they start dripping within a year, all cheap plastic insides.
One other choise is to remove the encloshuer you have and install a nail on one instead. There at least 3 times thicker then a glue on.
Old 03-20-2012, 12:15 PM   #7
Rewards Points: 101
nail on style? didn't even see that option at the store. I haven't installed any enclosure yet, just finished the drywall and tiled the floor last night. I'll look for a nail on style and see what I find. Thanks, 1
Old 03-20-2012, 03:17 PM   #8
Rewards Points: 101
update: I just went to HD and all of the nail/screw type enclosures I saw are designed for a certain tub that I did not purchase and install so they won't work for my application.
Old 03-20-2012, 05:03 PM   #9
DIY staff
I've never used Glacier Bay--Call their customer service line and see what the tolerance is for depth in the wall.
Change the drywall for Durrock and waterproof it with Red Guard before tiling.
A properly done tile surround should give you over 20 years of service---Will you be able to get repair parts for that brand of mixer in 10 or 15 years? Can you even get them today,if needed?
Old 03-20-2012, 05:37 PM   #10
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I've never used the Schluter-Kerdi products. But you might check them out. My understanding is that is about the only way drywall (even the moisture resistant stuff) is allowed in a tiled shower.
http://www.schluter.com/8_1_kerdi.aspx
Old 03-20-2012, 06:06 PM   #11
Rewards Points: 101
fair enough, since it looks like I'll be removing the drywall anyway I guess now would be the time to replace the mixer with a better model. I'll go with the Durrock/RedGuard as suggested. Thanks for leading me to the right way. 1
Old 03-21-2012, 05:10 AM   #12
DIY staff
Moen and Delta would be the top two choices in my experience---
Old 03-21-2012, 10:10 AM   #13
Rewards Points: 101
I went to the house last night and it turns out it's an American Standard, not sure if that's ok or if I should step up to a better model. must have got my wires crossed as one of the cieling fans is a Hampton Bay. I bought a gallon of the Red Gaurd it looks like just a gallon might be enough, didn't realize it was going to be almost $50.00 but if it works then well worth it. thanks, 1
Old 03-21-2012, 05:47 PM   #14
DIY staff
American Standard is a troublesome brand--no parts available except from the company---if you have trouble you will need to mail order the repair parts.
$50 well spent--I use Hydroban--almost $90 a gallon.(but a well spent $90)
Shower surround with window freakinjosh Carpentry 5 10-19-2011 10:10 AM
Shower Surround & drywall transition mchull Drywall & Plaster 5 08-19-2010 03:31 PM
Tub Surround Install Question tmbrink Remodeling 5 02-13-2010 05:02 PM
Tiled Shower Surround Help CluelessNewbie Kitchen & Bath Remodeling 4 02-10-2010 09:33 AM
Removing single piece of siding shortagain Remodeling 4 01-02-2006 10:12 AM
