1/8 Ply Behind Tub Surround? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-14-2012, 11:51 PM   #1
1/8 ply behind tub surround?
I am planing to install a new tub surround. its a glue to stud type..... my concern is that its pretty flexible and if someone fell they may pop a hole threw the surround wall between studs.
looks like I would be able to cut 1/8 ply a few inches smaller then the edges of the surround. I would screw this to the studs then glue the surround to the sheet of ply to better support it. the edges of the surround would still mount down around the flange as its pretty flexible and I have some shimming room.
its a surround so in theory no water should get behind it and it will be caulked at all seems. is this a good or bad idea?
lucky6man is offline   Reply With Quote
Old 02-15-2012, 06:25 AM   #2
If it is designed to mount directly to the stud, it is strong enough as is. Nothing else needed unless the directions say otherwise. If you are not happy with that, add some horizontal 2x4's between the studs.
Old 02-15-2012, 09:38 AM   #3
Rewards Points: 13,712
There is no glue to the studs enclosheres. It's nail on or glue on over Green drywall, which one is it.
1/8" plywood would have about 0 strength.
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 09:56 PM
Is H20 resistant sheetrock ok behind an f-glass surround? Jeffrey H Plumbing 6 11-01-2010 06:30 PM
Surround Sound Hookup Options Branden Home Theater 3 10-06-2010 02:40 PM
Tiled Shower Surround Help CluelessNewbie Kitchen & Bath Remodeling 4 02-10-2010 09:33 AM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 10:52 PM
