1/4" Drywall Requires 1/4" Backerboard? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 09:22 PM   #1
1/4" Drywall requires 1/4" backerboard?
I'm getting ready to redo our shower and floor in the master bath. I'm nearly 100% sure that my walls are 1/4" drywall. The house was built in the 50s. I haven't started removing the existing tile that's on the wall but I'm pretty sure when I do I'll have to start from scratch. The shower has been leaking somewhere around the base, I think. If the walls are 1/4" drywall, does that mean I need to use 1/4" backerboard? Everything I have read says 1/2" for wall applications. If I have to use 1/2" what can I do to make the backerboard and the drywall flush? Also this is my first time doing anything like this.
One more question.... I think I'm going to go with Custom Building Products' WonderBoard. Their website says you do not need to use tape, a.k.a. tapeless installation. Should I tape anyway?
Any input would greatly appreciated!
aweekendwarrior is offline   Reply With Quote
Old 09-22-2011, 07:59 AM   #2
I doubt very much it is 1/4" drywall. It could be 3/8 rocklath with plaster, common in the 50's. But any tile should go on 1/2 backerboard.
Old 09-22-2011, 08:54 AM   #3
Rewards Points: 5,336
An unremodeled '50's bath will probably be a mud job. Tile, concrete and wire lath.
Closer to 2 1/4" thick.
Ron
B. Franklin 1759
Old 09-22-2011, 09:27 AM   #4
Rewards Points: 256
I'd never use 1/4 backerboard on anything but a well supported floor.
If you tile job is from the 50's, and still in tact, there's no way its on 1/4 drywall (aside from not being common practice in that era)
michaelcherr is offline   Reply With Quote
Old 10-06-2011, 11:08 PM   #5
Military Mom of 4
Snav's Avatar
If your shower has leaked then what you need to do is tear out all the wallboard (and maybe the flooring) - expose as much of your joists/studs as possible in this area to access the plumbing. Check for a water-barrier skin (that goes on the joists/studs - underneath your backerboard).
This would give you a clean slate to put down new backerboard - putting you in control and in full knowledge of what condition your bathroom shower is in.
I would also suggest using hardibacker instead of wonderboard. Wonderboard is a bit crumbly and doesn't respond well to cutting and handling - hardibacker is smooth and more sturdy.
Yes - you should mud, especially if you don't have a waterproof skin under your backer board.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 64 12-12-2014 05:15 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 02:23 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
