1/2" Hardibacker Up To Solid Surface Shower Pan - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-18-2010, 09:52 AM   #1
Question
1/2" hardibacker up to solid surface shower pan
Question: So, the shower pan mfg suggested that the backer installs up to the small ledge of the pan which is about 1/4" thick and 1 1/2" high. He mentioned it will not fit flush and the backer board will protrude out leaving about 1/4" delta from the surface of the pan lip and the surface of the backer board. He also mentioned that when tiling, the tile will then come all the way down to the top surface of the pan, even thought there will be 1 1/2" of dead space due to the shower lip and backer board mismatch as I stated above. Assuming this approach is correct, I had planned on adding silicone where the two come together to make sure it's sealed. Does all this sound correct for this type of install? I'm not comfortable with the 1 1/2" (1/4" deep) of dead space. Thanks.
PaulJ is offline   Reply With Quote
Old 04-18-2010, 10:33 AM   #2
DIY staff
Rewards Points: 7,174
Typically that space is filled with thinset as you install your tile.--Mike--
Old 04-18-2010, 10:37 AM   #3
Okay...great thanks!
The Following User Says Thank You to PaulJ For This Useful Post:
oh'mike (04-18-2010)
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
Hiding shower pipes Jackamus Kitchen & Bath Remodeling 2 10-29-2009 04:30 AM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 12:01 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 10:33 AM
Hardibacker on shower ceiling? sharisavage Remodeling 6 10-06-2005 11:40 AM
