Old 04-18-2011, 02:10 PM   #1
Zurn Pex install tools & non Zurn fittings
Hi ,
I own a set of the Zurn crimp tools for use with Pex tubing & Zurn fittings—my question is, can these tools be used with non Zurn Pex fittings? Has anyone had any issues related to the Zurn installation tools and non Zurn fittings?
Any insight would be helpful.
ToolMonger
ToolMonger is offline   Reply With Quote
Old 04-23-2011, 09:45 AM   #2
Just call me Andrew
I just did a heating zone in my basement with the zurn tool, zurn rings, but non-zurn fittings and tubing. Worked fine....
I used Wisbro HePex tubing, not sure the manufacturer of the fittings.
Andrew
secutanudu is offline   Reply With Quote
Old 04-23-2011, 10:28 AM   #3
Plumb or Die!
All PEX pipe, fittings and crimp rings are (theoretically) manufactured to the same specs and standards. Jusy like how all copper fittings work with all copper pipe.
plumber666 is offline   Reply With Quote
Old 04-23-2011, 10:28 AM   #4
Just call me Andrew
I used the cinch-style rings (not crimp rings). I think those have to be zurn to work with my tool.
Andrew
Tags
zurn tools n fittings
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 03:18 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 04:35 PM
