Zoeller Drain Pump Trips GFI - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-27-2009, 01:25 PM   #1
zep
Zoeller Drain Pump trips GFI
Zoeller 105 - Model 53 Drain Pump with basin.
The drain pump, which is used for pumping washing machine water via a laundry tub, has stopped working and has tripped the GFI outlet. Every time I plug it back in the GFI outlet it trips. In addition, I ran an electrical cord from another GFI outlet and it tripped as well. Any ideas what may be causing this to happen? My thanks in advance.
zep is offline   Reply With Quote
Old 12-28-2009, 08:02 AM   #2
Rewards Points: 1,646
Pump could have an internal short that GFCI is sensing. Could be a bad GFCI. Do other items plugged into GFCI cause it to trip? How old is pump?
bob22 is offline   Reply With Quote
Old 12-28-2009, 08:22 AM   #3
the Musigician
DangerMouse's Avatar
sounds like it's time for a new pump, if it trips both tested gfci's...
DM
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Whirlpool Duet front loading washer drain pump Jrr1099 Appliances 1 04-08-2009 01:57 PM
Sink Drain Pump Vent Handyman101 Plumbing 0 03-11-2009 11:43 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
noisy shower drain pump zoodemon Plumbing 5 10-04-2006 12:22 PM
