-   -   Zoeller Drain Pump trips GFI (http://www.diychatroom.com/f7/zoeller-drain-pump-trips-gfi-60396/)
zep 12-27-2009 01:25 PM
Zoeller 105 - Model 53 Drain Pump with basin.
The drain pump, which is used for pumping washing machine water via a laundry tub, has stopped working and has tripped the GFI outlet. Every time I plug it back in the GFI outlet it trips. In addition, I ran an electrical cord from another GFI outlet and it tripped as well. Any ideas what may be causing this to happen? My thanks in advance.
bob22 12-28-2009 08:02 AM
Pump could have an internal short that GFCI is sensing. Could be a bad GFCI. Do other items plugged into GFCI cause it to trip? How old is pump?
DangerMouse 12-28-2009 08:22 AM
sounds like it's time for a new pump, if it trips both tested gfci's...
DM
