-   -   Yoke vent for water closet (http://www.diychatroom.com/f7/yoke-vent-water-closet-9842/)
kenlog 07-12-2007 11:06 AM
I am doing a remodel. Below is a sketch of the waste and vent for the water closet (W.C.), with the 2" or 3" ABS shown as solid line. There is a window directly above the W.C., so the vent has to travel sideways for at least 40" before going completely vertical. I don't see anything in the IPC or UPC about W.C. venting using a yoke vent as shown. The UPC is the local code. I will be replacing the old high quality, high flow toilet with a low flow toilet, as parts are no longer available for the old one.
1) Is the yoke vent as shown allowable within UPC? Is there a maximum allowable vertical distance from the W.C. to the yoke vent?
2) The horizontal vent section is about 12" long and is below the W.C. Is that allowed by UPC?
3) The dashed line indicates a possible reroute that would remove the horizontal section of vent. Is that a good idea in order to better meet code and minimize chances of future vent blockage?
4) If these arrangements do not meet UPC, does anyone have a better idea of how to drain & vent?
http://s208.photobucket.com/albums/b...C_YokeVent.jpg
kenlog 07-12-2007 12:07 PM
Better image
http://i208.photobucket.com/albums/b...g?t=1184259976
Ron The Plumber 07-12-2007 07:01 PM
1 Attachment(s)
UPC options to vent a toilet. What you have is not allowed.
kenlog 07-13-2007 03:31 PM
Ron the Plumber: Thanks for the info. I can understand how the first 2 dwgs. would meet code, but doesn't the third dwg. include a dry horizontal vent that is lower than 6" above the flood level of the toilet? Wouldn't it be necessary to vent 45 deg. or greater from the horizontal drain of the toilet?
Ron The Plumber 07-13-2007 06:34 PM
Yes if you need to vent under the floor back to a wall then you will invert the wye at 45 degree above center line, then run horizontal 1/4" per foot, then at wall a long turn is required.
