Yellow PVC For NG Service - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-05-2010, 04:15 PM   #1
Stupid Hurts ....
Yellow PVC for NG Service
Ok, So I've located a gas leak under the concrete patio on the extension for the spa heater, BBQ, and firepit.
Gas is turned off and Gas Co is aware.
My dilema ..... I have dug down from the coated steel riser in the firepit . The coated steel is attached to a vertical stub of yellow pvc. I see that the 90deg & 45 degree fittings on the underground, horizontal yellow pvc are white pvc (not to code for NG service). I know that white PVC is not allowed for continuos service.
My questions:
#1: Would it have been ok for the installers to put white pvc as junction pieces "after" the gas shut off(Dante Key) valve since they would not see continuous service?
#2 What is the likelyhood that they used white pvc as couplings under the concrete if they used them after the shut-off valve for the riser? I have yet to dig down for the spa heater and BBQ to see what 90 deg couplings were used on those locations since they have a continuous feed.
All in all, I see this as going to be a royal pain in the a**.
NikNak501 is offline   Reply With Quote
Old 06-05-2010, 07:01 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is the Yellow PVC just like schedule 40 water pipe or is it the flexible stuff?
Journeyman Plumber
Lennox service valve questions leeh1212 HVAC 12 07-26-2013 09:59 AM
Service mast options bsperr Electrical 6 12-09-2009 09:48 AM
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 09:14 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 11:00 PM
