Yellow Gas Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-16-2011, 06:56 AM   #1
yellow gas pipe
Can I use a yellow gas pipe for water
elliotboswell is offline   Reply With Quote
Old 10-16-2011, 08:57 PM   #2
Nope.
VIPlumber is offline   Reply With Quote
Old 10-16-2011, 09:01 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Journeyman Plumber
Old 10-16-2011, 09:17 PM   #4
Old 10-17-2011, 12:28 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
I think the problem would be that the next person to come along would wonder why someone hooked a gas line to the faucet.....
One of the reasons it is 'discouraged' to use a black wire as neutral or a red wire as earth ground.
Old 10-17-2011, 06:59 AM   #6
Rewards Points: 1,216
I would think Blue pipe would be more suited for water usage.
COLDIRON is offline   Reply With Quote
Old 10-17-2011, 08:53 AM   #7
JOATMON
ddawg16's Avatar
Blue for COLD water....RED for hot water.....GREEN for the hot/cold that comes from a mixing valve.
Ok...joking aside.....when you do work in a factory....you appreciate very quickly when pipes are painted the right color....especially when you have a bunch of them going all over the place.
Here is an example.....imagine working on something like this if the pipes and wires were not the right color.
Old 10-18-2011, 06:16 AM   #8
That looks like a large DA tank for some pretty good sized Boilers. The lines I can see should be labeled with directional arrows on them.
Old 10-18-2011, 08:26 AM   #9
JOATMON
ddawg16's Avatar
Actually....it's a 30' x 70' autoclave. This one is used to cure the front fuselage of the Boeing 787....42' of fuselage in one cure.
I don't have a pic of the completed project....but nitrogen pipes were painted green, gas black w/yellow strips, and water blue. The stainless steel lines are for cooling...this thing can get up to 450 deg F at 150 PSI.
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 12:31 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
Whatís the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
