-   -   yellow gas pipe (http://www.diychatroom.com/f7/yellow-gas-pipe-120259/)
elliotboswell 10-16-2011 07:56 AM
yellow gas pipe
Can I use a yellow gas pipe for water
VIPlumber 10-16-2011 09:57 PM
Nope.
Alan 10-16-2011 10:01 PM
:eek:
VIPlumber 10-16-2011 10:17 PM
:huh:
ddawg16 10-17-2011 01:28 AM
I think the problem would be that the next person to come along would wonder why someone hooked a gas line to the faucet.....
One of the reasons it is 'discouraged' to use a black wire as neutral or a red wire as earth ground.
COLDIRON 10-17-2011 07:59 AM
I would think Blue pipe would be more suited for water usage.
ddawg16 10-17-2011 09:53 AM
Blue for COLD water....RED for hot water.....GREEN for the hot/cold that comes from a mixing valve.
Ok...joking aside.....when you do work in a factory....you appreciate very quickly when pipes are painted the right color....especially when you have a bunch of them going all over the place.
Here is an example.....imagine working on something like this if the pipes and wires were not the right color.
http://i43.photobucket.com/albums/e3.../Autoclave.jpg
COLDIRON 10-18-2011 07:16 AM
That looks like a large DA tank for some pretty good sized Boilers. The lines I can see should be labeled with directional arrows on them.
ddawg16 10-18-2011 09:26 AM
Actually....it's a 30' x 70' autoclave. This one is used to cure the front fuselage of the Boeing 787....42' of fuselage in one cure.
I don't have a pic of the completed project....but nitrogen pipes were painted green, gas black w/yellow strips, and water blue. The stainless steel lines are for cooling...this thing can get up to 450 deg F at 150 PSI.
