Yellow Flex Pipe For Gas - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2012, 11:11 AM   #1
Retired NYPD
Yellow flex pipe for gas
How expensive and easy or difficult is it to run flex pipe for a gas stove? The length is about 10 ft.
FrankLa is offline   Reply With Quote
Old 02-06-2012, 11:17 AM   #2
Rewards Points: 12,818
Easy and simple to do but you should not be doing it.
Your gas supplyer should be doing it.
Your also going to need a shut off valve behind the stove and a flex line run from the supply to the stove.
Done wrong and house goes boom.
Old 02-06-2012, 11:42 AM   #3
Lavid2002's Avatar
Rewards Points: 85
+1 get someone certified. Each appliance has to have a shut off valve at the wall.
Lavid2002 is offline   Reply With Quote
Old 02-06-2012, 12:28 PM   #4
Retired NYPD
This is inside a wall and will have 2 shutoffs. One at the beginning and one at the stove. The run is 20 ft. Is this good to do or not? I will run black pipe if this is not a good idea.
Old 02-06-2012, 11:23 PM   #5
Frank,
If you're running a gas line inside of a wall then black iron is the way to go. Then, as Joe mentions, a flex line from the wall to the appliance.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
plummen (02-06-2012)
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 01:31 PM
Replacement of existing drain pipe from Kitchen and dishwasher RogerM Plumbing 1 10-13-2011 02:48 PM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 02:42 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 05:01 PM
