Old 12-07-2012, 10:59 AM   #1
Yello Polly gas pipe sizing
Is 3/4 inch yellow polly gas pipe the correct size for a sixty ft run between LP tank and house?
Randall Woods is offline   Reply With Quote
Old 12-07-2012, 12:16 PM   #2
call me E
TheEplumber's Avatar
Not enough info.
Google LP gas sizing
Old 12-07-2012, 12:41 PM   #3
You also need to factor in pressure and total load. I'm assuming you mean 60' from tank to second stage regulator at the house?
hvac benny is offline   Reply With Quote
Leaking drain pipe under kitchen sink dethun Plumbing 20 09-26-2012 08:30 AM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 04:47 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 06:17 PM
Sizing well pump drop pipe benjamincall Plumbing 3 10-29-2009 12:39 PM
Gas pipe sizing, Massachusetts almostdone Plumbing 1 01-31-2009 01:17 AM
